xzyHollyxyz
Aug 05, 2014Explorer
OP HERE.
The charge controller was just at $50.
The adjustable things are (as stated in the "manual"):
1) Voltage charging station
2) Undervoltage protection voltage
3) Undervoltage recovery voltage
4) Load control
I have no idea what any of those things are, except perhaps a slight inkling of Load Control.
Here is an example of how the "manual" reads (verbatim):
TO CHARGING FAILURE HANDLING METHOD
a) Solar energy to battery charging, if there is no correct configuration solar panels of power or exceed rated charging current, voltage, will appear charge fault, the checking and debugging, press XX the button, recoverability work.k
The sun had already set before I remembered I had a small inverter in my truck to be able to put a load on the panel. So, I'll give it a try tomorrow and report back in! :)
4) Load control
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
