BFL13
Aug 06, 2014Explorer II
Ok it works :) Now use the setting buttons to set that "PV OFF" figure to say 14.8v. That is the "ceasing charging" voltage the battery will then reach before the controller starts "controlling" ie, stops the voltage from getting any higher.
AFAIK that will also be your chosen Float voltage, so reduce that to say 13.2v if your batts are full and you are not using the trailer for a few days.
The 34C means I am glad I am not there! :) BTW keep the controller in the shade, where it can't get rained on either, not sitting out in the sun when installed.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
