BFL13
Aug 06, 2014Explorer II
greenrvgreen wrote:
BFL, what does "Controller PWM 13.7v" mean? Would this have something to do with Float?
Also, it's not the heat, it's the humidity.
That is the actual voltage (be same at panel as at battery) It is on a full battery but with a 40w load so it is doing 3.x amps (divide by 10 rule) to run that load
At the moment the Vabs is set at 13.8 and batt is there except for that load to 13.7. Float and Vabs are the same thing with this controller (same as my Solar30--seems to be made by the same company or to some same standard display method)
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
