xzyHollyxyz
Aug 08, 2014Explorer
OP HERE...
This is what you guys are talking about, right? I found this in an article online:
The voltages at which the controller changes the charge rate are called set points. When determining the ideal set points, there is some compromise between charging quickly before the sun goes down, and mildly overcharging the battery. The determination of set points depends on the anticipated patterns of usage, the type of battery, and to some extent, the experience and philosophy of the system designer or operator. Some controllers have adjustable set points, while others do not.
Here's the complete article, if any other new solar guru-wannabees are interested:
An Introduction to Charge Controllers
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
