happy2rv
Sep 20, 2019Explorer
Are the flickering lights switched individually or by a single switch? Do they flicker in unison? How much of a flicker? Do they actually go completely out or just dim and brighten? Is it fast or slow? Are they regularly timed consistent flickers or intermittent?
It could be a loose connection somewhere, as Ken suggested. If its regularly timed consistent flickers though, its more likely something else. It could still be a loose connection which is being vibrated, but is more likely some load on that circuit pulling the voltage down. Does it matter if all of the lights are on or not? In other words if just the light by the shelf is on does it still flicker?
Are these LED lights?
