Skline01
Sep 21, 2019Explorer
The four lights in the bedroom are on one switch and flicker in unison. The flicker is ver slight and quick. The same situation with the ones over the bedroom shelf.
I remembered that I had used a charging station for iPhones that is in the same area and that charging station had been a problem before. ( I had it looked at by an RV repair facility and for $200 they “fixed” it by rewiring. somethings - that was a year ago and I have used the charging station very little since then
I unplugged the phone that was charging when I remembered and the lights still flickered. This morning when I got up all was well and the lights did not flicker. I suspect the charging station was the problem - that it over heated and created the issue.
I am a novice with RV electricity. I think I will not use the charging station again and then have the whole system checked out when I get home. I have 10 days of travel before I get there.
Thanks to you guys for taking the time to reply.
