Looking into having the axles flipped on my 30' gooseneck horse trailer. I need to raise the rear of the trailer 2 to 3 inches Anyone done an axle flip and how much did it cost?
The amount of lift will be determined by the diameter/radius of the axle plus the thickness of the spring pack and the perch. If you measure those parts and picture how moving them from above to below you will see how much lift you will get.
Usually it's around 4 to 5 iches. I would pull the trailer on to wood blocks until it is sitting level then measure the thickness of the blocks. That is the amount of lift you need.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
