pianotuna wrote:
However the RV will be in storage from november 20 to march 10 and the Solar will be floating the bank.
Don, what BFL13 says above makes a lot of sense.
It sounds like what your AGMs REALLY NEED is a two-stage-output charger and a two-stage-output solar controller (both of those being temperature compensated). The two stages would be 14.XX volt temperature compensated range for initial fast(er) charging and a lower 13.6 volt temperature compensated range for combination long term taper-charging and floating.
I don't know much about available solar controllers, but good luck finding a temperature compensation two-stage charger except for this one - which you and BFL13 are aware of:
http://www.bestconverter.com/4455TC-ParaMode-with-TempAssure_p_164.html#.Vcv2t3GCb21Here's it's voltage output curves showing it's two output stages .... with a wide value-range for each stage as each stage is adjusted for temperatures surrounding the battery as reported by it's probe:
https://bestconverter.3dcartstores.com/assets/images/Parallax/4400/4455%20Voltage%20Curves.pdf
