bob213ExplorerAug 20, 2015Floating neutralI understand that my Honda 2000i has a floating neutral and my Progressive Ind. PT30C sees that as a fault. I've been able to get around that by using a neutral/ground bond plug. My question(without...Show More
bob213ExplorerAug 21, 2015Thanks guys. Saved me a trip to storage to check it out. I'll go with my single plug.I see there is a 3rd ground wire.Do you have to use a screwdriver to connect it?I replaced the Phillips head screws with thumb screws so no screw driver needed.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
Related ContentNeutral to Frame vs Floating Neutral QuestionLifepo4 float setting?Open neutralFlying Floating FlooringNeutral lines reversed
