pnichols
May 18, 2018Explorer II
Our motorhome is always powered up while being stored, so I just plug a BatteryMinder's input side into one of the RV's 120V receptacles and plug it's 12V output receptacle into an always-hot 12V receptacle in the motorhome's dash. The BatteryMinder then automatically takes care of the engine starting battery 24/7.
However, your idea of going 12V to 12V directly using the RV's built-in charger/inverter is very interesting. You might have to hand-make a special cable with a male 12V plug on each end to be able to easily go from RV 12V receptacle to cab dash 12V receptacle.
A BatteryMinder does not supply a steady voltage for battery maintenance, like an RV's stock fixed voltage inverter does. The BatteryMinder uses a varying voltage for maintaining batteries - which is supposed to be superior to a steady float voltage.
