MEXICOWANDERER
May 18, 2018Explorer
Mutha Fletcha's Do It Herself Cheater Cord
Use a fistful of dirt cheap Schottky axial diodes.
Look here comes some now...
https://www.ebay.com/itm/10x-15A-45V-Blocking-Schottky-Barrier-Diode-Rectifier-15AMP-For-Solar-Cell-Panel/201851510453?epid=697039277&hash=item2eff499eb5:g:EewAAOSwxEpYxpcd
The band on the diode case goes toward the chassis battery. Use a handful in parallel and crimp into a large butt connector -- one on each end.
Make up the cigarette lighter plug. Good a good one so it's easy to yank before starting the engine.
Heat-shrink both ends up to but not including the barrels of the axial diodes. Leave the barrels open to dissipate minor amounts of heat.
ANTI GYRO GEARLOOSE ANSWERS TO ARGUMENTS...
Yes this works fine and is dirt cheap
Forget voltage drop arguments. A glob of Schottky 15-amp diodes will drop .2 volts on a bad day with a hangover. Sue me if dropping from 13.3 volts to 13.1 will negatively affect the storage life of a low antimony engine starting battery, it won't because some 40-years of doing exactly that proves you wrong. Keeping a battery mind you a low antimony battery that is not cycled at 13.1 volts is wonderful for the battery. The Delta T between 12.6 and 13.1 is a universe apart as far as effects on longevity.
If you forget to unplug and blow the cigarette light fuse, the hassle of replacing it puts you on a vertical learning curve experience.
There is nothing wrong with expensive bells, whistles, and flashing lights plug in battery maintainers except they needlessly separate me from my cash. Spend 3 dollars or spend 30 dollars. It makes no difference -- for this specific use your battery will not live ten seconds longer except if you live at McMurdo Sound, or Timbuctu Mali where temperatures are as crazy as the people who live there.
Yeah I'm a bit testy. I went to the doctor in the USA and forgot the cardinal rule of never eating there -- I am getting over a randy case of E-Coli and sometime today I have to scrub the sandal skid-marks off the tile between the bedroom and bathroom.
