BFL13
May 20, 2018Explorer II
It took about three hours to get the engine battery up to the same voltage as the house battery bank, so there they are in parallel floating.
I prefer to float the Wet engine battery separately from the AGMs, even if there is no good reason, so my actual method will be to use the little charger inside to the cig plug. That is better for me than using it outside clamped on, powered from the RV outside receptacle and extension cord.
The jumper could also be used when on solar.
So time to declare victory and quit while ahead!
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
