Itinerant1
Dec 06, 2020Explorer
BFL13 wrote:
Was setting up the TC again and ran into where I had to pick to have the converter able to run the rig with the battery wires off so the battery is not on a float (which it is not supposed to be unless not using the rig for more than a month per AGM routine) the TC gets used a couple times a month but has a modified AGM (SiO2) battery bank. That means never being on a float according to Trojan.
So that brings up anybody with an Inverter/charger. You can't run the rig on the charger part and leave the batteries disconnected, no load, so to meet the Trojan battery guide "rules".
That means you must float the battery bank no matter what when on shore power for however long. If that ruins your batteries, too bad!
With my Magnum inverter/ charger if on shore power I turn off the charging so the 120v is passing through powering the 5th wheel and the batteries are powering the 12v items, I could turn off (disconnect) the solar but leave it so it can recharge what little power that was used during this period of time (7-15ah, nightly), float till night. But then I guess lfp don't have the same constraints as lead.
