pianotuna
Dec 07, 2020Nomad III
BFL13 wrote:pianotuna wrote:
Hi BFL13,
I've heard, for greatest longevity, long term storage for Li is 40 to 50% state of charge. Not what I want.
If you are on shore power for a while, you can do that if you have a converter to make your 12v, but not if you have an inverter/charger. (An inverter /charger must be connected to the battery to operate at all--it needs the 12v from the battery to run its own systems)
It might be worth the approx $130 for a converter to rig up and by-pass the inverter/charger for 120v too somehow. If all you have is a single 12v Walmart batt, then it would not be worth the bother probably. What if you have a $3,000 Li battery bank and are spending the winter on shore power at some resort?
Hi BFL13,
I did leave my oem converter in place but unplugged, so I have that covered.
I think it is possible with an inverter/charger to set the charge rate to zero. I may be wrong about that. I have successfully set the maximum charge rate to 111 amps, down from the "flat out" 129 amps design.
I normally leave the solar maintaining my batteries during storage periods.
I chose to have enough solar to equalize the battery bank.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
