BFL13
Dec 07, 2020Explorer II
No equalizing with SiO2. Same as AGMs but with regular AGMs you can do a "recondition". I have my C's 6s sitting with no wires and will recharge when they get down a bit in voltage (spot checking with multimeter, since the Trimetric monitor draws power so can't be left on the battery with no wires on battery)
I have the chassis battery floating on the converter though. There is a case where you must leave a charger on between trips since it has loads on it (maybe not so much with a 1991) Solar is off (array to controller side disconnected)
No idea how to do it with a Trickle start with house no wires on, and no converter, only an inverter/charger. PT will have to invent something.
The TC has the SiO2s. I pulled the Chev's Stud 1 fuse so the chassis batt and the SiO2s are not in parallel (I gather there is nothing wrong with that, but I still don't feel good about doing that--so I don't!)
If not using the truck for a while I put a maintainer charger on the truck battery. I was going to float the SiO2s, but now I want to do the no-wires between trips but they are hard to get at, so I will have to arrange a disconnect switch to the battery post where I can get at that. The converter can still do the 12v.
It might be a case with the SiO2s and the TC scenarios we have, that I might as well just float them and to heck with it. Be easier for sure.
