pianotuna
Dec 08, 2020Nomad III
BFL13 wrote:
There is no data on what you lose in number of cycles /lifetime by floating when you really shouldn't between trips according to the guidelines.
Actually there is inferential data.
In my travels on the wobbly wide web, I found out SiO2 used in "float" situations have a life span of 18 years. If they are cycled to 50% the life span drops to 7.67 years.
In my case, the SiO2 may exhibit a lifetime guarantee, as I'm no longer full time--and the solar system will keep them in float between trips. In fact, I plan to not worry about cycling below 20%.
