BFL13's avatar
BFL13
Explorer II
Nov 29, 2020
Floating vs Storage Voltage Question
Moved this from another thread to open the topic generally. Question was if PD converters with the 13.2 storage voltage were compatible with floating voltage specs at 13.5 and above.
Many (all?) battery specs have the same floating voltages (2.25 a cell or so) My AGMs did and also the flooded batts I have had.
PD's are used successfully with all those other batteries according to various reports
Trojan eg, has 2.25 too, and says not to float either flooded or AGM at all if they will be charged frequently. ("cyclic use"?) So the PD's "storage" mode at only 13.2v is confusing. Is "storage" really "float" or something else?
https://www.trojanbattery.com/pdf/TrojanBattery_UsersGuide.pdf
Float is supposed to just make up for self-discharge so 13.5-13-8 typical seems high for that, unless it is GC2 6s?
Resting voltage of a full flooded is more like 12.8 so 13.2 is more above that. My ordinary AGMs spec resting at full was 13.0 though, and nobody said a PD is no good with AGMs.
Now I am not sure what "floating" vs "storage" is all about. Anybody explain? Thanks.
  • Interesting about that US Battery float voltage for flooded at 2.17 per cell. Their AGM is 2.23
    Meanwhile Trojan is at 2.25 for both types, and East Penn (Deka) is at 2.24-2.26 for AGM and 2.30-2.35 (13.8-14.10v) for flooded.
    Seems they all agree on AGMs but are all over the map for flooded batts.
    We have had many posts about how 13.8 is too high and how you have to keep adding water at that voltage, saying 13.2 is required to stop that. But the battery specs are as above for 77F.
    EDIT--Note that Trojan says not to float floodeds if they are used more than once a week, but say for AGMs it is if they are used more than once a month.
  • Lots of battery myths would be corrected if RVers would read the Trojan Users Guide.
  • 13.2 works well when combined with the 15 minute boost charge at 14.6v every 20 hours.
    Otherwise storage and float are the same thing as far as I am concerned.
    Although if the battery has been floating in storage for an extended period I do find that first cycle is a bit weak and seems to restore on the first charge cycle. Might be virtually the same to let them just rest disconnected for storage.
  • BFL13,
    The best is to have the voltage vary with the temperature of the battery. That feature is available on most good solar charge controllers, and also on high quality inverter/chargers such as Victron.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 31, 2025
