tkcas01's avatar
tkcas01
Flojet Portable Macerator - disconnect each time?
The instructions that came with the unit say "do not mount permanently to the RV Waste Port." This makes me wonder, if I am at a relative's house for a couple of months, is there any problem with leaving it connected? It does hang down below my rig, so I was thinking of wrapping plastic around it when not in use to protect it from any moisture that might splash up during heavy rains. Do others leave them connected when at a site for an extended period, or have you had issues when doing this?
  • I think the major concern would be the extra weight stressing the sewer outlet as you bounce down the road. That would not be as much of a concern if you are sitting in one place.
    My main concern would be leaving a relatively expensive piece of equipment exposed to the elements unnecessarily. Another concern would be in the position the pump is when it is hooked onto the sewer outlet, it seems like water would lay right up against the impeller and seal for the whole time, which can't be that good for the seal.
  • A simple twist, and it is off. The bayonet connector part of the pump cost about $65, and hanging below the TC it is easy to break. I always take mine off, but I really do see where it would make a difference if the dump valves were closed. They do sell permanent mount Flojet pumps. The connection appears to be the only difference.
    Wayne
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
