MEXICOWANDERER wrote:
When I FLOAT a loan, I guarantee there is going to be flow, regardless of my bank balance.
Whatever is powering the float charge, power supply, panel, etc. has to be sending amperage of some quantity to the battery. Think about it.
Some of you are trying to measure amperage in -el place wrongo-
The device powering the float does something for a living.
Just remembered. My battery monitor is in series to the negative wire coming from the batteries. In other words, the negative wire comes from the batteries directly to a bus bar then through the shunt and off to the chassis ground. The monitor uses a 500mA shunt though. Not sure if that makes any difference here.
The far left in this pic is the shunt.
