myredracer
Jun 05, 2016Explorer II
dfpalyu wrote:
2016 Keystone floor covering is not sticking to plywood. Any suggestions?
Where/how are you finding this? Is it bubbled somewhere or somehow damaged? Does it need a repair somewhere? Cuts and patches can be done by using seam sealer. Best to let a pro. floor layer do this.
Sheet flooring is not glued down onto the subfloor. They staple the flooring around the outside perimeter only and build everything on top of it. It does make for easy removal if you ever need to say as when installing laminate plank flooring.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
