rayroof10 wrote:
No l,m not going to junk it.the roof and wall,s or in great shape. just the floor,l,m tearing it out to replace l was just asking if anyone elso had this kind of problem.
Yes, floor rot is a very common issue with ANY RV..
Water will find its way a LONG ways from the actual leak, mine had a weak spot in the MIDDLE of the floor and the floor was all vinyl! Water had made its way down from a window and the water heater under that window and then pooled in the center of the floor UNDER the vinyl.
Fix is not all that hard to do but it will cause you to find creative ways to get all the rotted wood out and replace with new wood..
You want to cut back the rotted floor until you find SOLID undisturbed wood. I used a 7 1/4" circular saw with the depth set to just a little over 1/2". Then I made a plunge cut in to the floor.
This type of cut is made by holding the back of the saw in the air and placing the front of the saw on the surface to cut. If you can picture the saw at a angle without the blade touching. Then pull back the blade cover and turn saw on then drop the back down while the front is still touching the floor. You can move the saw forward or even backwards doing this cut.. Works great when you have the space but if you are near a wall or cabinet you may need to use a vibrating type saw which can get up close to walls.
You want to cut back the floor to the NEXT joist and ideally leaving a little of the existing joist exposed (this gives you a place for your new floor to sit on).
Once you find good floor you will need to remove and replace any wood structure under the floor which is rotted/soft. Once all damaged wood has been removed then you will need to sister in a replacement joist. Sistering is nothing more than a added 2x2 beside the bad joist, screw new 2x2 into the good portion of the existing joist.
In between joists you will need to add a 2x2 from each joist (this gives your new and old floor something to rest on). Slip the 2x2 halfway under the old floor allowing half of that exposed.
Now you simply cut a new piece of plywood to size and lay it down, using adhesive and drywall screws.
To dress the joint around the new and old floor I used a neat trick I had seen on a home repair show.. TIGER HAIR! Mixed up some good old tiger hair resin (what you would use for car sheet metal repairs, tiger hair has LONG fiberglass strands) and filled in the cracks. Sanded that flat then cam back and used autobody filler (this is similar to tiger hair but contains no fiberglass and sands down smooth). Sanded that then I painted the floor with kilz primer and a coat of flat wall paint to seal the wood and give a nice clean surface for the new vinyl to lay on.
Involved? You bet.
Expensive? No, unless you are paying someone to do it..
Easy? No, this is not an easy repair nor will it be a few hrs, most likely will take you a good weekend just to find all the bad spots and cut them out..
Worth it? Pretty much as long as you don't mind doing the work yourself. It will be cheaper than going out and buying a new trailer.
