Lynnmor
Jun 23, 2019Explorer II
SoundGuy wrote:IAMICHABOD wrote:
is a major PITA to use and setup and makes a lot of noise.Lynnmor wrote:
That is correct, but if you NEED one, then you do need it.
Don't understand the "PITA" part :h, using a FloJet is certainly a cleaner and easier method of off loading black water than fooling with a stinky slinky and way too expensive, too heavy wheeled tote tank. :)
Dealing with a huge tub full of 1/2” 50’ hose, 3/4” 75’ hose, wiring, and switch, then connecting them is a PITA. Then draining the two hoses, coiling them and stuffing them in the tub is a PITA. Finally draining the pump and allowing it to dry before is another inconvenience.
