SoundGuy
Jun 23, 2019Explorer
Lynnmor wrote:
Dealing with a huge tub full of 1/2” 50’ hose, 3/4” 75’ hose, wiring, and switch, then connecting them is a PITA. Then draining the two hoses, coiling them and stuffing them in the tub is a PITA. Finally draining the pump and allowing it to dry before is another inconvenience.
What "huge" tub of hose? :h I lay my hose out at the beginning of the season beside the house foundation where it runs down to the inlet stack I installed on the house main stack. There it remains til the trailer is stored for the winter.
What wiring? :h Mine is permanently installed on the trailer, wired out to a standard Bargman connector beside the waste gates. Just plug the FloJet in and use it.
What two hoses? :h One 50' 3/4" to send the macerated pump output to the sewer intake stack when servicing the tanks at home. When camping I have a 25' 1/2" grey water hose I normally use for gravity draining grey water but should I need to macerate & off load the contents of the black water tank I use the same hose.
Draining the pump and allowing it to dry? :h Guess I must have missed this even though I've owned a FloJet since 2006. Wow, what an eye opener! :S
