I want to get a wand to flush the HWH, but don't want all the sediment getting into my water pipes, do you guys have any issues after flushing the tank with sediment getting into the pipes and cloggi...
I remove drain on WH tank.........then turn on water supply and lets it flush out the WH tank while stirring things around with a piece of stiff wire (I use an old welding rod).
Then when the large chunks (if any) stop flowing out I turn off water supply and then finish flushing/rinsing with the wand. Stick it in pointed up and blast away.
Next time I use RV I just pull aerators on kitchen sink and flush lines (hot/cold) thru it before any other faucet/shower is used
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
