CapnCampn
Apr 18, 2017Explorer III
I was going to suggest a resistor spark plug, as someone else did too - they're cheap too for a quick test, then you've also got a spare!
It's not quite as cheap of a test as just running the gen while not connected, but not bad. :)
I suppose step one would be check the existing plug to see if it is a resistor version.
Good Luck!
CC
Good Luck!
CC
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
