74vette's avatar
74vette
Foam tape on inside of slide-where to find
I am in need of new foam sealing tape on the inside of the slide where it contacts the wall when the slide is extended. The foam on there now is a 1 1/4"x3/4" square tape. Is there another product I could use as a replacement for the foam tape?
Thanks
  • Just a note to my search for the foam seal. I did find the correct sealing material, it is made by AP products #018-821125. This is a low density NEO.EDPM 1"x 1 1/2" by 25 feet. This material is required for the slide to make the proper seal on my trailer. I tried the D-seal and it just flattened out and did not work.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
