D_E_Bishop
Oct 30, 2014Explorer
RJsfishin wrote:
His "severe grade" must have not been as severe as yours.
But I learned something new,......this is the first I knew of a carbureted vehicle w/ an "in tank" fuel pump.
I had an 84 Itaska 454 w/ only the engine pump. Many had an external rear pump, but mine never gave a problem.
Good luck on the results,....you deserve it !
You're right, my grade was up to 6% and about three miles.
And the mechanic has an '89 Southwind without the in tank pump which is why he said he didn't check. I guess they had to overcome the heat problem Harvard mentioned.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
