dtappy3353's avatar
dtappy3353
follow up to "Existing Wiring in Ceiling"
Yesterday I posted the above topic and received great feedback from the group.
I planned on installing a new Fantastic Fan in our fiver Eagle's bedroom ceiling replacing the current screen vent. I was concerned about where I could get electricity to run the new fan.
Advice received as to remove interior shroud/sleeve which may expose wiring. Did that and found only 2x4 framing....no wires.
This a.m. I sent an email to Jayco requesting electrical and plumbing schematics of my trailer.
Within less than 1 hour...all of my requests were received via email.
WOW. You talk about service! I know for fact that I couldn't have gotten this type of cooperation from the local dealership!
THANKS AGAIN JAYCO! I WILL BUY ANOTHER FIVER
  • kampinguru wrote:
    I had the same thing in my trailer. There was a light in the ceiling close to the vent. I drilled a hole in the 2X4 and fished the wire to the light out with a coat hanger and tapped into it. I had the Fantastic Fan with the remote so did not wire a wall witch in.
    Exactly what I did.
  • I had the same thing in my trailer. There was a light in the ceiling close to the vent. I drilled a hole in the 2X4 and fished the wire to the light out with a coat hanger and tapped into it. I had the Fantastic Fan with the remote so did not wire a wall witch in.
  • Almot's avatar
    Almot
    Explorer III
    Yes, there can be 2x4 around the vent nest.
    OP - the schematics will be of little use if you can't access wire nuts buried deep in the ceiling. See what you can find around the ceiling light, I wrote in the last post of that 1st thread.
