- pianotunaNomad IIIVictron probably makes one of the 3 best inverter lines available. There is nothing that comes close to this quality vs price point in a small inverter.
I've never blown a fuse on any inverter I owned.pnichols wrote:
I always read the reviews on products.
This PSW inverter has only one review and it seems fair the way it's worded. Read the reviewer's "Cons:" and "Summary:" comments ... very telling.
I would be a bit leery of purchasing this PSW inverter. - SlownsyExplorerI bought the 375W Vitron 240V after for my fridge which is a Mitsubishi 410L inverter fridge I resently instaled after the old gas 110V conked out. Ouer FW is now part 110v part 240V
Frank. - pnicholsExplorer III always read the reviews on products.
I would be a bit leery of purchasing this PSW inverter. - LittleBillExploreri ended up adding anderson power poles to switch between battery clips and dc plugs. worked out ok. might be a option for most
LittleBill wrote:
I believe it is an SB50 connector that will accommodate pins for #6 wire max.
even the go power requires anderson power poles
#4 into a 300w inverter is a bit of overkill IMO.- LittleBillExplorer
beemerphile1 wrote:
pianotuna wrote:
My 12/350 does not have posts. I wish it did.
Thanks, I already have 4 gauge to the location where I am considering replacing a MSW with a PSW. I'll keep looking.
get some split bolts wrap it up, and call it a day. even the go power requires anderson power poles - beemerphile1Explorer
Thanks, I already have 4 gauge to the location where I am considering replacing a MSW with a PSW. I'll keep looking. - pianotunaNomad IIIMy 12/350 does not have posts. I wish it did.
- GordonThreeExplorerHere's the 12/350 from the Victron website
Looking at the PDF for the smaller Phoenix it's confusing. Some pictures show permanently attached wires, others show binding posts. I wonder if their graphic artist drawing the mock-ups was having a bad day, or what exactly.
see here:
PDF
Non serviceable fuse is a bummer, but it seems common. - beemerphile1Explorer
pianotuna wrote:
Hi folks,
I find this an amazing deal at 90 bucks. I purchased one and it is double the weight of the inverter I was using before.
https://smile.amazon.com/gp/product/B01EW5ZA94/ref=pe_344980_272415450_em_1p_0_ti
The one and only review says it has 10 gauge wires soldered on, is that how yours came?
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 05, 2026
