  • 200%
    TWICE THE POWER OF
    TRADITIONAL BATTERIES
    1/2
    HALF THE WEIGHT
    5X
    CHARGES UP TO 5X FASTER
    4X
    LASTS 4X AS LONG
    100%
    SAFE & RELIABLE
    From Dakota's LFP site. Gottaluvit!
    ( I am in the T-1275 "camp", but get by ok with 6s)
    We had a run of AGM claims for "5 x faster" too.
    --3 tons, do you have measurements of your solar harvest from before you got LFPs and from afterwards, with same conditions, so we can "see your work" and do a peer review on that?
  • 3_tons's avatar
    3_tons
    Explorer III
    From my perspective I found that the test was interesting though not surprising since (for those who have ‘actually’ switched from wet-cell to LiFePo4) it merely validates our real-world, non-theoretical experiences with now some actual empirical data - ‘Shoot the messenger’ comes to mind (let the ‘battery wars’ begin!!”) - it seems that thread after thread the LiFePo4 deniers (ATTACKS) are limited to the SiO2 camp, who have even denied LiFePo4’s lower internal resistance (thus, optimizing solar peak period harvest)...I can’t help but find this theme (abject bias) curious?
    3 tons
  • Bend wrote:
    I have no dog in this discussion. Just passing the info:
    https://www.youtube.com/watch?v=iy3hga_P5YY
    Interesting!
    That show's introduction by Igor, Dr Frankenstein, and Herb Tarlek is "interesting" for sure. "Amazing" even! :)
    https://www.google.ca/search?q=Herb+Tarlek&sa=X&biw=976&bih=462&tbm=isch&source=iu&ictx=1&fir=faklWchhTl7fzM%252C2HT-YIlcYI7OxM%252C_&vet=1&usg=AI4_-kS6rMowCkcO2B44CKyVkKznp-D32g&ved=2ahUKEwii7bat9f3uAhURsJ4KHRr6D88Q_h16BAgiEAE#imgrc=faklWchhTl7fzM
    Pix for Mex.
  • Hi,
    I got that from one of the sellers pages. Heat and Li don't party well together.
    Here it is with the source:
    "To sum up, for long and happy LFP battery life, in order of importance, you should be mindful of the following:
    Keep the battery temperature under 45 C (113 f) (under 30C if possible (86 f)) – This is by far the most important!
    Keep charge and discharge currents under 0.5C (0.2C preferred)
    Keep battery temperature above 0 C (32 f) when discharging if possible – This, and everything below, is nowhere near as important as the first two
    Do not cycle below 10% – 15% SOC unless you really need to
    Do not float the battery at 100% SOC if possible
    Do not charge to 100% SOC if you do not need it"
    The above are from https://www.solacity.com/how-to-keep-lifepo4-lithium-ion-batteries-happy/
  • pianotuna wrote:
    Bend,
    What about hot weather testing? Damage on LiFePo4 starts at 86 f, and they should not be charged when the temperature is 113 f.
    where did you get that? all the specs I have read on lfp say 60C for not charging them anymore and the normal operating range for max temp is 40 to 50C. would kinda be usless if you were dammaging them at a little bit above room temp dont you think?
    Steve
  • Bend,
    Lead acid batteries do not reach their full capacity until they are cycled 25 to 30 times. This makes the whole test invalid from the get go.
    The cold weather test was a joke if you live pretty much anywhere in Canada.
    I find it hard to believe that they would not use temperature compensated charging with sensors on the batteries.
    They also did not test what is possibly the best of the lead acid formats which may be SiO2. SiO2 have a much lower Pukert number than most other batteries.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 22, 2025
