MEXICOWANDERER's avatar
Apr 02, 2016
For FLUKIES $108.00
Features :
Compact design, you can one-hand operation.
Large-screen display of 2000 characters.
200A AC and DC current, 600V AC and DC voltage measurement.
3000 ohm resistance range, continuity test.
Zero function, can be cleared for DC measuremtns show.
Keep reading.
Specifications :
Fluke 362 Range Resolution Accuracy
AC Current 200A 0.1A 2 % ± 5 counts(45 - 65Hz);
2.5% ± 5 counts (65 - 400Hz)
DC Current 200A 0.1A 2% ± 5 counts
AC Voltage 600 V 0.1 V 1.5% ± 5 counts (45 - 400Hz)
DC Voltage 600 V 0.1 V 1% ± 5 counts
Resistance 300 / 3000? 0.1 / 1? 1% ± 5 counts
Continuity Test <=70?
Size Dimensions 205 x 60 x 22 mm
Clamp opening 18mm
Weight (g) 196
Security Level CAT III 600V
Package includes :
1 x Original Fluke 362 Jaw True-rms AC DC Clamp Meter
1 x User manual
http://www.banggood.com/Original-Fluke-362-Digital-Detachable-Jaw-True-rms-ACDC-Clamp-Meter-p-974155.html
  • Gjac's avatar
    Gjac
    Explorer III
    SparkDr wrote:
    Fluke...when you care enough to buy the very best. Great, professional-quality products.
    I think you are right, but as a non professional and getting more forgetful as I get older I get the free ones from HF. I have a friend that is a professional and I use his Fluke to adjust my HF multimeters (there is a small pot inside for DC voltage). One meter I left outside and it rained on it, another I pumped gas on it while checking the fuel pump on the generator, I gave several away to other Rvers that didn't have one, another I probably left on a stump next to Roy B's. If I ruined or lost a Fluke that I paid over $100 for I would feel really bad. I'm sure most on here are more carful than I.
  • Fluke...when you care enough to buy the very best. Great, professional-quality products.
  • RoyB's avatar
    RoyB
    Explorer II
    I got the CRAFTSMAN version of this from Sears a few years back for around $60 and it was 400AC AMPS and 400DC AMPS.
    Now I can't find it. Probably left it on a tree stump on one of my OFF-ROAD Camping runs..
    A very handy meter to use by just clamping around the wire.
    Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,359 PostsLatest Activity: Feb 10, 2026
