gtnsmlrExplorerSep 17, 2018For gen techsI'm running my 50A rv service with a Honda EU6500 connected to the 30A 240V receptacle. Everything works fine. My question is, would long term durability be improved if I switched to the110V only sett...Show More
MrWizardModeratorSep 17, 2018what else is using 120v power fridge ? water heater ? converter ?might be better to just swap some breakers around in the power centerto balance the load put them on the other legyou have 23amps per leg in the 240v mode using the (4) wire 240v outletmoving circuit breakers to shift and balance your load is the best optionyou have an unbalanced load , it will still be unbalanced even on 50amp shore powerthis is NOT a generator problem
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
