gtnsmlr
Sep 17, 2018Explorer
For gen techs
I'm running my 50A rv service with a Honda EU6500 connected to the 30A 240V receptacle. Everything works fine. My question is, would long term durability be improved if I switched to the110V only sett...
MrWizard wrote:
what else is using 120v power
fridge ? water heater ? converter ?
might be better to just swap some breakers around in the power center
to balance the load
put them on the other leg
you have 23amps per leg in the 240v mode using the (4) wire 240v outlet
moving circuit breakers to shift and balance your load is the best option
you have an unbalanced load , it will still be unbalanced even on 50amp shore power
this is NOT a generator problem
