ov10mech's avatar
ov10mech
For the electrical gurus. Getting 50 Amp off two outlets?
I am considering buying a 5th wheel that has two air conditioning units with 50 amp service. The location where it will be placed permanently only has 30 AMP service, so I will not be able to run both at once. However, there is a standard outlet about 20 feet away from the camper that could technically give me the juice needed to un that 2nd AC when I need to. The question is - is it possible to somehow combine these two power sources into a single 50 AMP input? Its a bit easier on a boat because there are two separate input plugs.
  • Personally I would not do it. Retired industrial electrician.
  • I think I may have found my answer?
    https://www.homedepot.com/p/Camco-50-Amp-Power-Grip-Power-Maximizer-Adapter-55025/205518970?cm_mmc=Shopping%7cTHD%7cG%7c0%7cG-BASE-PLA-D26P-Plumbing%7c&gclid=CjwKCAiAxarQBRAmEiwA6YcGKE1e7p1jLh-mk3u2R7vX0o3WKXEEFOksSqxPdYobRehoXU8vvB-hAxoC0RIQAvD_BwE&gclsrc=aw.ds&dclid=CJS3iaKPv9cCFYitaQod3CkBuw
