72cougarxr7
Sep 04, 2019Explorer
I would recommend a Stant "superstat" if you can find one. It is their premium thermostat line and is made of stainless steel, has a larger opening to flow better, and has a larger heat motor for more accurate opening.
If you are running 200 to 205, that is not bad. The thermostat is likely a 195, so 190-200 would be the normal temp range.
The existing thermostat could be old and getting slightly lazy, causing it to open a few degrees hotter than spec .
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
