winnie32v
Mar 22, 2014Explorer
Ford 4R100 Transmission Question/Problem/Advice
I have a 2001 Winnebago Adventurer 32V built on a 2000 Ford F53 Chassis with a V-10 and 4R100 Transmission.
It has 45,000 miles on the unit.
I bought this motorhome about 2 years ago at 41,000 mi.
I changed all fluids.
I drained the 4R100 torque converter and dropped the pan and replaced all of the fluid with new Dex/Merc transmission fluid.
This year while returning from Florida to Pa. I noticed a "transmission shudder" when the transmission downshifted to 3rd at approx 3,000 RPM.
When the "rumble strip chatter" started, I would just let off of the gas about 1/8" and the chatter would go away.....when I gave it a little more gas, the chatter resumed.
Sounds like the transmission clutches.
When the unit downshifted to the next lower gear...at appx 4000 RPM, there was no chatter.
NOW, I have found out that the 'Dual Purpose' Dex/Merc is NOT supposed to be used to replace the original Mercon transmission fluid.
SO........I have also found out that the "Old" Mercon original fluid can be replaced with the better synthetic Mercon V oil.
My task this summer is to drain the torque converter (yes, this year has the drain plug), the pan AND gently blow out the cooler tube (15 psi) and replace the better fluid with Mercon V fluid.
So a couple of questions:
1. Did I do any possible damage to the transmission using the Dex/Merc fluid?
2. From anyone's experience, will the Mercon V cure the clutch shudder problem?
Also, I should add that I went from a 2000 Jeep Wrangler soft top as a tow vehicle to a 2008 Jeep Grand Cherokee....maybe an additional 1500 - 2000 lbs tow.
I DID notice the extra weight when I was going up the hills.
This probably amplified the transmission issue and brought it to my attention !!!!!!
The engine runs great and everything else is running fine.
Please advise from your experience with the 4R100 transmission and let me know if I'm doing the right things to get me back to Florida this winter.....OR....anything else that might refer to this situation.
Thank you for your time and advice.
Regards,
Paul
Regards,
Paul
