HiTech
Mar 09, 2013Explorer
pianotuna wrote:
Hi,
There is a firm that does have 17.5 inch wheels--but tires are probably scarce. Scarce means expensive.
I'm going to go to wider tires from LT225/75R16 to LT245/75R16. Be sure there is room in the wheel wells.
The extra carrying capacity may allow me to lower the tire pressure and smooth out the (bumpy) ride.
Be very careful. You need clearance above and beyond the max dynamic sidewall deflection for the flex of the sidewalls plus an air gap, not just static space when measuring tire to tire sitting still. This might require a wheel spacer.
Jim
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
