pianotuna
Mar 10, 2013Nomad III
Hi harold,
I plan on larger width rims. I run 14,000 pounds fully loaded (full gas tank, full water tank, two persons, rack on back and food.)
I want to have a "cushion" above the 14,500 pounds the chassis is rated at. I want to have slightly greater ground clearance. I want to have a gentler ride.
There are, with the current 225 75R16 tires zero sway or handling issues.
My existing Michelin tires are from Jan 2004, and I have 100,000 kilometers (60,000 miles) on them. There are no wear issues on the tires, and plenty of tread. The RV was 5 years old with 7000 kilometers on it when I purchased it, in Feb of 2009. I drive it about 1600 kilometers (1000 miles) per month on average.
The rear duals are run at 80 psi and the front at 65 psi.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
