rondi
Mar 06, 2014Explorer
pianotuna--where did you get your new wheels? Do you know what the max air pressure is for them?
In my prior post I mentioned i considered the Hankook 7.50R16LT tire which is a Load Range G tire, but has the same load rating at 80psi as my stock tires. since the wheels are probably rated at only 80psi (this from my local Ford parts dept) i canceled that order and now I'm considering the 17.5 commercial duty real truck tires.
Ron
Ron
