rondi
Mar 06, 2014Explorer
pnichols--one of the main reasons is to increase the Load Rating from E, which is a 10 ply tire to an F or a G. You can't do that with the stock wheels--which are matched to the tire limit of 80psi--per my local ford dealer's parts dept.
In my case the weight on my rear axle is over the 9600lb limit with virtually nothing added in the rig--it came overweight from the factory! I guess there is no law or regulation that forbids that--but common sense should. I had 2 leaves each side added to the stock 11 leaf spring pack to raise the rear a couple of inches--and they did that. Ford is the one to blame here. The E450 they spec at 14,500lbs and provide LR-E wheels & tires, whereas an F350 (rear axle copied from the online spec=9650 lbs. (F-350 DRW)) and has 17," 18" or 20" (F-250/F-350) truck tires and this isn't even an F450. Ford knows their rig will be overloaded and probably tell the dealers--just watch all the class c rigs come in for the chassis work that you'll get :)
The rigs made today are almost identical to the ones made in the first part of this century.
And remember--very, very few rv owners even know about these forums, and are driving around unaware they are overloaded. We know some.
Ron
Ron
