time2roll
Oct 20, 2020Nomad
So have you been on a three hour drive without the trailer and no issues?
I would be leaving the truck running and check the truck battery voltage. Check direct on the battery terminals and check on the connectors. s/b the same and more than 13.2 volts. Post the results.
Then shut down the truck and check again. When it fails again check voltage while cranking. Post all results.
I recommend to carry a jump box while this issue persists.
I really doubt it is the trailer.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
