time2roll
Sep 08, 2022Nomad
Mnewbill wrote:What is the voltage on the battery terminals just before you shut it down?
Hi I have a 2019 f150 5.0 with the same symptoms. It struggles to crank after hauling the travel trailer. I dont know if the battery is low as it will start fine after it cools off. It may be bad battery but it's fairly new in terms of years and low miles. It should have at least 2 more good years. Any luck finding your issue?
Otherwise I would assume the battery needs replaced.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
