brirene wrote:
I received a letter from Ford in December for "Special Field Action 09L02" addressing this issue on my '05 F350 4x4. I don't know if it would apply to yours, but I'll paraphrase:
It has come to our attention that some owners of F-Super Duty 250/350 4x4 vehicles have experienced severe steering wheel and front wheel vibrations and oscillations after treveling over a bump or dip in the road. Ford motor Co and the National Highway Traffic Safety Administration have been studying this condition, sometimes known as shimmy.
What is the issue?
Your vehicle may experience shimmy, a severe vibration and oscillation in the steering wheel that begins after the vehicle travels over a bump or dip in the road and does not dampen out by itself. The condition may cause the cab of the truck to vibrate significantly.
Shimmy differs from the more typical, slight oscillation of the steering wheel that may occur immediately following wheel impacts and disappears on its own This type of steering wheel oscillation is a normal characteristic of most trucks, especially a 4x4 vehicle with a solid front axle.
What should you do?
To prevent shimmy:
Maintain recommended tire inflation pressures
Some SD customers intentionally lower the tire predssures on their truck to change the ride characteristics. If you do not maintain the tire inflation pressures at the levels specified by Ford, your truck may experience shimmy. This condition results from significant tire under-inflation. Please visit the National Highway Traffic Safety Administration's website (www.safercar.gov) for more information...
Tire pressure should be checked and set with cold tires before the vehicle is driven...
Use only Proper Replacement Tires
Only install LT load range E replacement tires that are the same size, type and speed rating as those originally installed...
Do Not Make Suspension Modifications
Ford does not recommend the installation of after-market lift kits, stabilizer bars, or replacement parts that are not equivalent...
IF YOUR VEHICLE EXPERIENCES SHIMMY:
In the event our vehicle experiences shimmy, you should slowly reduce speed by either lifting off the accelerator pedal or lightly applying the brakes. The shimmy will cease as the vehicle speed decreases.
Seems rather simplistic, but IIRC I got the same notice about a year ago as well. Good luck.
Techno BS... Basically nothing more than Ford washing their hands of the problem... Pushing it to the customer to find and fix.
This IS a well known issue, not just with Ford but any 4x4 can exhibit this problem. The folks at Dieselstop seem to have a handle on the problem and the fix is the track bar...
