Golden_HVAC
Jan 23, 2016Explorer
Is the brake light working?
When I had my exhaust system installed, I found that the cruise control was not working on the way home. My RV was only about 13 months old, and I was upset that it broke. When I got home, I discovered that the emergency flashers had been left on by the mechanic who parked my RV in front of their shop, while I was doing the paperwork to pay the bill.
Turning off the emergency flashers allowed the cruise control to work fine, and I have had no further problems with CC over the past 15 years. I did have to replace the turn signal flasher relay, and have had no problems with it's replacement in 15+ years.
My emergency flashers stopped working when the flasher relay was not working, so replacing it, and the emergency flashers worked normally.
So I guess I would ask
Do brake lights work?
Did you replace the round turn signal flasher relay?
Does your cruise control still work?
Good luck,
Fred.
Good luck,
Fred.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
