BFL13's avatar
BFL13
Explorer II
Jan 19, 2020
Ford Starting /House Charging Question UPDATE Test
New test 20 Jan.
The solenoid in the sig rig only closes the line between the engine battery/starter/alternator and the house batts when the engine is "on".
What happens when you turn the key to start the engine? At some point the solenoid closes so the house and engine battery/alternator are linked and the alternator can charge the house batts.
Is there a point at which the key is turned and the starter has not yet cranked the engine, when the house and engine batts are all on line to provide the amps to operate the starter? Or is it just the engine batt doing that, and the house batts are connected to the alternator afterwards?
I know the alternator can't do anything until the engine is running to turn the belt, but is the line connected before that?
Thanks.
