NinerBikes
Aug 27, 2015Explorer
My basic test was start the motor up, then disconnect the negative side of the battery. Does it still run? Alternator is good, could be the voltage regulator. Does the motor die? Alternator is probably bad, test for output voltage and amperage, as well as voltage regulator.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
