MEXICOWANDERER
Aug 27, 2015Explorer
116 year old man found flat on the floor. Some will argue that a change in diet would fix the problem, even though he has lain there for three weeks.
A 3-G, 4G, or 6-G will start raising battery voltage INSTANTANEOUSLY when the engine is started. IMPOSSIBLE for it to not to do so. The FUSIBLE LINK that connects power to the cab, the ignition switch and the reference voltage regulator A connection and the S lamp excitation circuit on the alternator, also powers the key switch, lights, and fuel pump. Been there done that. Ford protects the alternator against LOAD DUMP due to a failed fusible link.
I like the idea of RETAINING the original rotor and the original stator, using 50-amp dish diodes instead of the original 30-amp dish diodes and sticking with a brand new voltage regulator. The 3-6 G uses eight rectifiers instead of six because it has a rectifies Y connection. Take a look a the STATOR winding color through the case holes or slots. is the wire colored magenta/purple? If yes you have the highest-amperage model of that alternator line. If the stator color is GREEN the alternator is not the highest amperage model. Hope this helps.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
