MEXICOWANDERER
Aug 30, 2015Explorer
Exactly correct senor Westend. If you get battery but no test light in either of the remaining connectors check for a glowing ALT light on the dash. A glowing when probed ALT light means that alternator volt reg connector is seeing good signal to fire off the reg. Volt reg should climb to 14.4 then sag as reg temps climb unless you have a really hot day.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
