fj12ryder
Aug 20, 2015Explorer III
Fulltimer50 wrote:Okay, those just look like standard slide-up windows. I had read that they don't put the frameless windows in the slide-outs because they protrude and cause problems with the slide seals. That has been the only place I've seen the windows that slide up, in the slide-outs I mean. Thanks for explaining.fj12ryder wrote:
Fulltimer, you have frameless windows that slide up and down? How do they work? I've never seen those. I was under the notion that all the frameless windows just cracked open at the bottom.
Best I can do now. If you look at the window on the side of the slide, perhaps you can see how the window works. I took pics but dont have a web page to post them where you can see them.
PIC
PS While they look to be frameless they are not. The frame is on the inside. The window is glued to the frame from the outside.
So there are no frameless windows that open other than popping open at the bottom?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
