SGTJOE's avatar
SGTJOE
Explorer II
Sep 12, 2020
Freedom Remote Control Panel
This is in my 2001 National Tradewinds and was wondering if it is supposed to light up when I'm not connected to power (50amp) It does light up when I'm plugged into shore power. The picture is of the Freedom Remote Control Panel
  • On shore power you should have the charger part enabled and 12v for those things that need that.
    No shore power, now you are on battery for all 12v including for the inverter.
    So is there some disconnect so you are not on inverter at all with no shore power? Or is it just the remote that doesn't work, but you are still getting 120v from the inverter to run 120v things and 12v from battery to run those other things?
  • Appreciate that but my Inverter is a Xantrex Freedom 458 series. And yes I have the books, just not smart enough to understand them.
  • SGTJOE
    I've got a Freedom 25 Inverter/Charger with a Link 2000 controller in my motorhome. I've also have copies of the owner's manuals. If you have the same let me know and I can email you a copy.
  • dougrainer wrote:
    did you not read the responses on your other post in Motorhome forum? Doug
    Yes I did, but no one answered my question. The remote panel inside lights up showing charging, volts etc when I am plugged into shore power. But is does not light up if I shut down shore power. Is this the way it works or do I have a problem.
    So I thought if I came over to Tech issues I would get a better answer.
  • did you not read the responses on your other post in Motorhome forum? Doug
  • Any thoughts as to how to post the picture. It's of my Freedom Remote Control Panel inside the MH. The panel does come on when I'm plugged into shore power but doesn't show anything when I disconnect the shore power.
  • If you're trying to post a pic from your computer or phone, that doesn't work.
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
